G60 Bob 0 Posted September 29, 2005 Reving my G60 above 5000rpm for any length in time results in oil temps rising rapidly from 106-110 to anything up to 125-130 depending on how long im giving some but the water temp never goes any higher than 100*C. Oil teps come back down after 5-10 mins of normal driving. Is this normal because im starting to think somthing is reading incorrectly or broken? I plan to get an oil cooler before fitting a chip and pulley but i dont want to start tuning it from standard if something isnt working properly and end up having my baby go kaboom! Quote Share this post Link to post Share on other sites
steveo29 0 Posted September 29, 2005 its normal for the oil to get that hot when driven hard for a while, you'l be fine with a oil cooler Quote Share this post Link to post Share on other sites
h100vw 0 Posted September 29, 2005 steveo29 said: its normal for the oil to get that hot when driven hard for a while, you'l be fine with a oil cooler Absolutely... Gavin Quote Share this post Link to post Share on other sites
Neil VR6 0 Posted September 30, 2005 Sitting above 5000 for a long time! Geez, that's rapid progess! In 5th that's over 100 isn't it? Quote Share this post Link to post Share on other sites
_Monkey 0 Posted September 30, 2005 My oil temp used to get all the way up to 155 at times. :onfire: Unfortunately that was shortly before my charger decided it needed a sunroof in it's own casing! :cry: The person who used to own it had bodged the oil pump with silicone!!! :nono: Quote Share this post Link to post Share on other sites
Henny 0 Posted September 30, 2005 At Bruntingthorpe I finally managed to get J-DUB's oil temp over 120 with my mocal, but that was doing flat out sprints up the 2 mile straight and shed loads of 0-60 sprints at the time... Get a Mocal oil cooler on it or change 5th for a longer gear ratio... Oh, and lose the lead wellys or you'll lose your licence!!! :lol: Quote Share this post Link to post Share on other sites
Neil VR6 0 Posted September 30, 2005 Mine's got to 114 after a motorway run and then sitting in traffic immediately afterwards but that's as high as it'll go with the Mocal. It's only a tiddly cooler as well. Quote Share this post Link to post Share on other sites
JT 0 Posted September 30, 2005 mine never goes over 114 on the motorway, my mocal is fitted right next to the rad.... has anyone fitted a way of feeding it cold air. or this not really needed, i just replaced my rad and on each side there are black plastic sides that bolt on to the side of the rad to direct ithencoming air straight onto the rad what about removing the left hand side one or something, basically wondered if i got more air moving around the mocal would it reduce the oil temps even more :?: Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted September 30, 2005 is the water temp the analog dial on the left? on mine it never seems to go over 70. think its broken. on my other corrado it stayed between 70 and 110. Or is that the oil temp on the left and also the oil temp on the MFA digital?? Quote Share this post Link to post Share on other sites
JT 0 Posted September 30, 2005 the analog one on the left of your fuel gauge is water temp, digital one of the mfa is oil temp..... Quote Share this post Link to post Share on other sites
Henny 0 Posted September 30, 2005 JT-G60 said: has anyone fitted a way of feeding it cold air. Yup! I've got mine where my intercooler used to be with the air scoop that used to feed the intercooler firing nice cold air onto it... 8) Quote Share this post Link to post Share on other sites
JT 0 Posted September 30, 2005 i've just been out and had another look at mine and the only way i reckon i could it is to fit one in the vents just above the splitter but it would deffinately need some kind of guard or mesh to stop anything flying up and straight through the cooler, Henny- is yours with a standard bumper :?: if it's ok with you might have a look at yours on the 27th, as i'm making a visit to to darren on monday and if all goes well will have the chip and pulley done, so would like to get this little mod done to keep the oil temp down as much as i can...... :D Quote Share this post Link to post Share on other sites
G60 Bob 0 Posted September 30, 2005 Thanks for the advice guys - now i just have to save save save! By the way i meant 5000rpm in each gear :oops: i havnt seen 5000rpm in fifth that many times as the oil temp seems to rise as fast as the speed when going that fast! Quote Share this post Link to post Share on other sites
Henny 0 Posted October 3, 2005 JT-G60, yup, standard bumper... the lower grill (the one just above the chin spoiler) should stop most road crap from hitting the cooler directly with enough force to burst it... mine's been there for about 20K miles so far (admittedly on 2 cars now :roll: ) and is fine with no signs of damage to it... 8) Anyone's welcome to have a look around my car on the 27th... 8) Quote Share this post Link to post Share on other sites
