chrishill
ETKA part number request
morning chaps! hopefully some kind soul with ETKA is about this morning?
I'm after part numbers for a 93 VR on the following...
Fuel Pump Relay (number 53 i think)
Bowden cable for heater direction dial (far left dial on heater control panel)
uh... the fluffy bit that goes around the outside of the sunroof! not sure on the technical term for it, i'll try and find a photo.
cheers!
please check these with the dealer before you buy as my copy is usa
relay 191 906 383 c in loc 12 bottom right first row above fuses
sunroof gasket 321 877 209 2460mm shorten to 2265 mm
only lhd cables listed on mine
535 819 831 cable for control flap
535 819 835 cable for defroster flap
535 819 837 cable for temp flap
the number your after would fall between those i think
Rob
cheers carpy, sunroof gasket eh? suppose that better than ringing up and asking for a fluffy thing!
i'm guessing the 'defroster' flap is the one that controls where the air blows from?
I think the direction control dial has two bowden cables attached to it. One does up to the screen (defroster), the other down to feet.
