xnology
No way to run VAG COM???
From everything I've read here and elsewhere, it looks like I can't run a VAG COM connector on my new G60. I have another '90 G60 with ABS and it seems it has the right connections to work with VAG COM, but I want to get rid of it because it --HAS ABS--!!!
They seem to be a little sketchy as far as dependability.
Mine is an H plate G60, doesn't have ABS. I have the brown wire for VAG-COM, but not the other two wires it needs. Apparently some just came without it from the factory.
Anything pre 1992 is most likely to be analogue (blink code) technology. VAG-COM is digital, so not compatible. Also, pre 1994 cars will need a 16 pin connector to a two x two black white connector converter.
Only if there are 4 wires to the 2x2 connectors. 1,2, & 3 wires only are analogue. 1992 model build only.
