Madjackal
What is PCD
the vr6 is 5x100 pcd 112 is from audi and the newer vw models
PCD stands for 'pitch circle diametre' and is the diametre of a circle drawn through the centre of your wheel's bolt holes. P.C.D. is measured in millimeters and also indicates the number of studs or bolts the wheel will have. Volkswagen Alloy Wheels are usually either 4x100 [i.e. 4 bolt holes drilled through the centre of an imaginary 100mm circle] or 5x100 [VR6s, GTis and MK4s]
