G60-R 0 Posted November 12, 2005 When i try to put my rear screen washer on it makes noise under the bonnet like it should be working but nowt comes out. Any ideas? Quote Share this post Link to post Share on other sites
Tekara 0 Posted November 12, 2005 Its most likely blocked. My rear wash used to work, but its now progressed to more of a dribble. Haven't found a way to unblock. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted November 13, 2005 Try unblocking the jet with a pin first and then take the black hatch trim off and disconnect the pipe to find out where the problem is... Quote Share this post Link to post Share on other sites
StuartFZR400 0 Posted November 14, 2005 As Supercharged says. you can also try blowing out crud from the pipes by taking them off, but they arre often brittle and easier to replace the lot for a small price. Assume the fronts work fine? Quote Share this post Link to post Share on other sites
G60-R 0 Posted November 14, 2005 yeah, front all good. cheers, i'll add that to my 'list of things to do on car' it seams to growing fast! Quote Share this post Link to post Share on other sites
VDUBBER 0 Posted November 16, 2005 I had the same problem with mine about a month ago. The problem for me was the plastic pipe that goes through the bottom of the wiper arm had broken off. Then i found a disconected water pipe if the that helps any?????? Quote Share this post Link to post Share on other sites
