Stakis 0 Posted November 13, 2005 Please tell everything you know about such conversion. What are the biggest problems? which parts fit from corrado? i am thinking about inserting g60 engine, with g60 gearbox, semiaxels etc.(everything what corrado have under the hood including suspension). Thank you very much for sharing your knowledge. Quote Share this post Link to post Share on other sites
Stakis 0 Posted November 13, 2005 my car is 1993 VW GOLF GT with 1,8 monoinjection. As i said, i am thinking to insert g60 motor, gearbox, clutch, joints, driveshafts, whell hubs, etc. will everything fit into my golf? Quote Share this post Link to post Share on other sites
VR6 0 Posted November 13, 2005 G60 into a mk3? May as well lob it in barge! Sorry, I can't help with the conversion but I'm just trying to work out why you're doing it. Surely the engine is best left in the Corrado? (Unless it's already been removed :)) Quote Share this post Link to post Share on other sites
Rob Heath 0 Posted November 13, 2005 Hi mate I know a bloke with this conversion, carried out by Grant motorsport For more info, put a post up on http://www.elite1000.co.uk general section HTH Quote Share this post Link to post Share on other sites
Stakis 0 Posted November 13, 2005 heh i can't register into this: http://www.elite1000.co.uk forum..;( VR6 > why you say what my plan is not good? Yes, exactly, i want to fit g60 into gollf mk3. Quote Share this post Link to post Share on other sites
gibber 0 Posted November 13, 2005 Stakis what do you want to know? my mk4 cabrio has a mk3 chassis so yes it does fit coz I done it, but it is as tight as you like! The basics, you will need your golf drive shafts, you will need to convert your car to hydraulic clutch, the cable shifter sort of bolts up but you need to make a small bracket to hold it at the front, erm think you have to swap the rear engine mounts, you will need to change your rad as the out let is blocked by the charger, the corrado exhaust fits aswell but the tail pipe will be a bit off. youwill need to fit a front mount intercooler, but a merc sprinter one fits nicely! :wink: ask me some stuff Quote Share this post Link to post Share on other sites
Stakis 0 Posted November 14, 2005 Thank you very much for the beginning, i know I will have a lot of problems fitting this motor into golf mk3. we though to leave orioginal golf gearbox, you left original? or placed a corrado gearbox? It would be better to fit corrado, but the gearshift system is different. What about changing the clutch to hydraulic one? how it can be done? (i have all the corrado front and all the parts that are under the hood). I think I will not have to change the radiator, because I am fitting a g60 engine with turbo conversion, and no g60 charger is left, so there is more free space in the front. Please say some other hints, or problems you had with this conversion. Thank you very much ;) I believe that soon I will have turbocharged golf mk3. Quote Share this post Link to post Share on other sites
gibber 0 Posted November 14, 2005 The standard 1.8 gearbox will not take the power, I rang stealth who told me that is it possable, but it will not handle 200 bhp. I used the corrado box, and fitted the gearshift system from the corrado. The clutch pedal is the hard part and needs some carefull measuring. Quote Share this post Link to post Share on other sites
Stakis 0 Posted November 14, 2005 you fitted the gear shift systemfrom corrado? it is diferent.. how you solved the question with the exhaust when fitted corrado gearshift system? What do you mean with clutch pedal? Quote Share this post Link to post Share on other sites
gibber 0 Posted November 14, 2005 where are you from? Quote Share this post Link to post Share on other sites
Stakis 0 Posted November 14, 2005 Lithuania, and sorry for my bad English..;) Quote Share this post Link to post Share on other sites
g-dub 0 Posted November 14, 2005 far out dude, long way anyway i have a friend who has a g60 in a mk 3 and as VR6 says it is slow so much difference between cars, and for some reason can only hit 125mph, such an overweight car Quote Share this post Link to post Share on other sites
Stakis 0 Posted November 15, 2005 golf is very simillar to corrado. and my motor beats vr6 in drag track easily. Quote Share this post Link to post Share on other sites
gibber 0 Posted November 15, 2005 Yeah my golf cabrio only wieghts 100 KG more than a corrado. You guys should check your figure before you quote things! Stakis your engish is fine, you are just not understanding what I type. Quote Share this post Link to post Share on other sites
Stakis 0 Posted November 15, 2005 heh, today is the lucky day, in the evening we will make a motor swap..;) we will try just to mount the motor, and all the job will be to wire everything correctly. If I will find more difficulties, I will ask you. Please give me your e-mail gibber? And thank you very much one more time. gibber > Your golf is cabrio, which means that it is minimum 100kg heavyer than all the other golfs..;) Quote Share this post Link to post Share on other sites
bix 0 Posted November 15, 2005 MK3 VR 1155kg....that would be lighter than a C VR! http://parkers.co.uk/choosing/specs/data.aspx?model_id=1015&id=5885 Quote Share this post Link to post Share on other sites
Stakis 0 Posted November 15, 2005 golf vr6 weights 1155kg corrado vr6 weights 1240kg..;)))) Quote Share this post Link to post Share on other sites
Stakis 0 Posted November 15, 2005 corrado g60 weights 1115kg... golf mk3 g60 will weight 1100-1120kg..;) so... Quote Share this post Link to post Share on other sites
gibber 0 Posted November 15, 2005 Stakis basicly mate, fitt as many corrado bits as you can gearbox - corrado sellector - corrado wiring loom - corrado clocks - corrado clock wiring loom - corrado drive shafts - golf Pic 1 was before the intercooler pipes came. Pic 2 with out the charger but with the second alternator fitted. Quote Share this post Link to post Share on other sites
VR6 0 Posted November 15, 2005 Quote You guys should check your figure before you quote things! Trying to regain some pride....... What figures and what did I quote?! ;) Quote Share this post Link to post Share on other sites
