saysomestuff
Shopping List
Hey Guys,
I;m going to rebuild my 2.0 9A engine over the xmas holidays, it's got 135k on it. Any chance some one could post up the parts I should replace?
I'm going to try to stick to some kind of realistic budget :)
Cheers,
definately removing the head, depending on what you guys suggest (pistons, crank bearings) I might pull the lot out. The aim of the excercise is to make it good for anoth 135k :)
The only reason I ask is that my judgement on whether something is worth replacing is poor lol. So if I just have a shopping list and do it all at once it'll be easier for me.
okay then...
To do the crank bearings you need to remove the engine from the car as the bearing at the end is a complete O rather than 2 half shells...
If you're removing the engine, it's time to do the clutch too...
so;
Engine out Basics:
Head rebuild including new seals, seats and guides
Get the block hohned out by an engineering shop, odds are the place that rebuilds your head will be able to do it for you... get 'em to check the state of the bores while you're at it to see if it needs a rebore or not.
Clutch kit
Piston rings (the pistons themselves will be fine as long as the bores aren't damaged)
Head bolts
Head gasket set
Full engine gasket set
Crank bearings
Big end bearings
Paint (well, you gotta make it look pretty! ;) )
Waterpump
Oil pump
Dizzy
Cam followers (this'll hurt 'cos there's 16 of 'em! :( )
Plastic water system parts (they're not expensive and you may as well change 'em!)
Engine mounts (all 3 of 'em - may as well while it's not in there!)
Wash the pistons in your dishwasher (don't laugh, it makes a big difference!) and then attack with one of those green pan scourers to get 'em spotless...
Make sure EVERYTHING is spotlessly clean before putting it back together again... 8)
Optional:
Crank lightening
Flywheel lightening
Bottom end balancing
Overbore with new pistons to take it to 2.1! :twisted: :lol:
Dremmel and sandpaper for porting out and polishing the inlet and exhaust manifolds and the throttle body...
Bigger valved head?
plastic water pipes and oil pump I'd go genuine, everything else you'll be fine with GSF/ECP parts... 8)
Price wise? Dunno, never rebuilt a 2.0 valver... :|
actuall all bearings are half shells. but the end caps of the block need removing for proper efficient crank removal, thats engine out
GazzaG60, you sure? I thought the crank end bearing was a complete ring, not a pair of half shells... :| Live and learn, it's a while since I took a crank out... :|
poped the crank out of mine last week ready for the overbore.
i already done about half of what you said for my turbo motor.
its 5 caps. 2 bolts on each (non stretch) with retainers on the centre cap.
Thanks for all this guys. So should I really be looking at a garage rebuilding the head then?
I'm trying to convince myself that I can't stretch to a CNC head , so we'll keep that out of the picture for now - I was planning to do it myself, I assumed the only specialist tool was a valve spring compressor
you need a press to put in the valve guides and a specialist tool for putting in new seats and cutting them properly with 3 lips...
There's no point in just putting new seals in, as if the guides have any wear in 'em they'll just leak after a few K miles...
CNC head on a Valver would be interesting... ;) Go-on, you know you want to! :twisted: :lol:
