Supercharged 2 Posted August 12, 2003 Just fitted new headlamp bulbs and the 'monobrow'... Only took about 30 mins to do if you don't include the 3 months it took me to build up the courage to drill through the slam panel and headlight covers... :roll: Quote Share this post Link to post Share on other sites
Andi 2,147,483,647 Posted August 12, 2003 That be proper bo, I tell thy! Quote Share this post Link to post Share on other sites
jedi-knight83 0 Posted August 26, 2004 i just got one of these....does it srcew into the lights then?? does it mean you have to take the eyebrow off to remove the lights in future??? cheers (ps notice how i did a search and posted in an old thread instead of just starting a new one :roll: :wink: ) Quote Share this post Link to post Share on other sites
Furkz 0 Posted August 26, 2004 COLOUR CODE IT...... 8) u can also use double sided tape which u use for the side trims....if u dont wanna get the drill out Quote Share this post Link to post Share on other sites
jedi-knight83 0 Posted August 27, 2004 yeah mine is being colour coded...but does is obstruct getting the lights out?? Quote Share this post Link to post Share on other sites
CazzaVR 0 Posted August 27, 2004 Yeh, it does. Only takes a few seconds to take it off though, so not really a problem. Quote Share this post Link to post Share on other sites
Scott 0 Posted August 27, 2004 Still trying to work out how to put mine on.... already bought it so might as well stick it on. Quote Share this post Link to post Share on other sites
jedi-knight83 0 Posted August 27, 2004 Only takes a few seconds to take it off though, so not really a problem well it would be a problem if i bonded it on!! thats all i wanted to know. i'll make sure i dont bond it now then. cheers Quote Share this post Link to post Share on other sites
kvwloon 0 Posted August 27, 2004 Supercharged, Looks good, same a smine, and favourite front end mod of mine, but would definately colour code it. Did you use those tungsten tipped screws from B and Q you bought ages ago?! :lol: Quote Share this post Link to post Share on other sites
jedi-knight83 0 Posted August 27, 2004 can someone post a pic of where and how they mounted / screwed it please. thanks Quote Share this post Link to post Share on other sites
Supercharged 2 Posted August 27, 2004 Did you use those tungsten tipped screws from B and Q you bought ages ago?! LOL, No - "never gonna use them" can someone post a pic of where and how they mounted / screwed it please. You get a fairly decent fitting kit and instructions with them... just go for it! Quote Share this post Link to post Share on other sites
jedi-knight83 0 Posted August 27, 2004 i bought it second hand (allthough its unused) so no instructions....would appreciate a scan if you have them Quote Share this post Link to post Share on other sites
Supercharged 2 Posted August 27, 2004 Yeah, I'm at work at the moment but can do - If you ring up Kamei tho they will end you a copy and fitting kit if your missing that too??? - I'll dig the number out for you later Quote Share this post Link to post Share on other sites
Ford 0 Posted August 27, 2004 I have just bought a rado with an eyebrow spoiler, that I would like to remove. It appears to be riveted on? Is that normal or am I missing something. Will get it removed when next at the garage.... Quote Share this post Link to post Share on other sites
jedi-knight83 0 Posted August 27, 2004 Yeah, I'm at work at the moment but can do - If you ring up Kamei tho they will end you a copy and fitting kit if your missing that too??? - I'll dig the number out for you later thanks that'd be grand....or a scan of the instructions would be even grander :lol: fitting kit is probably just some self tapper screws anyway :roll: Quote Share this post Link to post Share on other sites
CazzaVR 0 Posted August 27, 2004 jedi-knight83, when I fitted mine to my old G60 I used sticky backed velcro for each end, and drilled two very small holes for the middle. These drilled into the top inside corners of the headlight surrounds, which don't have any glass or anything behind. HTH Quote Share this post Link to post Share on other sites
G-Lader 0 Posted August 27, 2004 pretty easy to get off and re screw in, would not let having to screw the eyebrow in put u off. Quote Share this post Link to post Share on other sites
