SAV
CLOCKS
CAN ANYONE PLEASE HELP IM NEW TO THE G60 AND JUST OUT THE BLUE MY REV COUNTER SPEEDO TEMP AND PETRO GUAGE PLUS DIGITAL DISPLAY HAS ALL STOPPED. I CHECKED ALL FUSES BY DRIVERS SIDE THEY ARE ALL GOOD
THANX
Possible the voltage regulator in the cluster has blown. Provides a stabilised voltage to all these gauges mentioned. Looks like a heat sinked transistor. Sits usually for the G60 on the PCB behind the fuel gauge.
If it has gone, you may have a short somewhere on the PCB or the water temp sender or fuel tank gauge sender.
Part number 357 919 803. (applicable for all Corrados)
CHECKED all connections to cluster they are fine ive noticed that my temp and petrol gauge work fine. rev,speedo and digital displays are not
any ideas anyone
thanks
