Stan 24v 0 Posted November 26, 2005 Mate of mine with an M plate Storm is having probs with his fogs. As soon as he turns the lights on, his fogs (front & rear) keep blowing. He has changed the fuses and it keeps happening. Any ideas what could be causing it? Quote Share this post Link to post Share on other sites
stevemac 0 Posted November 26, 2005 I'm assuming it's the fuse that keeps blowing ? Sounds like a problem with the wiring - possibly going to earth somewhere. Has the front bumper been removed recently - wiring may have been trapped. If not, check the terminals on the back of the front fog bulb holders - wires may be shorting out. I assume he's using the correct size fuse ? Quote Share this post Link to post Share on other sites
Stan 24v 0 Posted November 26, 2005 Yeah its the fuses, and I think hes using the right ones. I'll speak to him tomorrow, cheers. Quote Share this post Link to post Share on other sites
RW1 0 Posted November 26, 2005 Simple switch/wire/bulb/earth circuit. Check bulbs for short. As Steve has said, trapped wire. What was fiddled with before if started. If nothing - bulbs. . Quote Share this post Link to post Share on other sites
crdo16v 0 Posted November 26, 2005 Simple answer is not to use the fogs, nearly every time I turn mine on if only for a minute or so the glass lens seems to crack shortly after. Seems to be one of the Corrado's Achiles heels :thumb right: Just keep my fingers crossed we don't get much fog. Quote Share this post Link to post Share on other sites
Stan 24v 0 Posted November 26, 2005 RW1 Thought as much Chris, will have a look for him. Simple answer is not to use the fogs, nearly every time I turn mine on if only for a minute or so the glass lens seems to crack shortly after. Seems to be one of the Corrado's Achiles heels :thumb right: Just keep my fingers crossed we don't get much fog. Not too good for MOT though. Quote Share this post Link to post Share on other sites
bristolbaron 10 Posted November 26, 2005 mine have been going actually! and 1 bulb was replaced by the bodyshop who sprayed the car.. will check wiring/bulb tommorrow!! Quote Share this post Link to post Share on other sites
stevemac 0 Posted November 26, 2005 bristolbaron, They may well have trapped a wire putting the bumper back on. Quote Share this post Link to post Share on other sites
