sharlie1982
Active spoiler no longer active
Ever since I bought my Flash Red 1992 C G60 back in May, the rear spolier has never really worked as it should, needing the boot to opened and closed to get it going again. :(
I know that it doesn't really have any practical effect on the car, but it does look a bit Porsche 911'ish, which is nice :D
Last month it has stopped working both manually and speed related.
Where do I start trying to fix this little problem?? :?
Any help please. :wink:
If you had to open and close the boot to get it working again, it sounds like there might be a broken wire in the rubber bit that goes between the main car and the boot lid - I'd start by investigating in there...
Yep, take off the plastic trim (takes seconds) and have a good look at the connections....
I assume evrything else is working fine? - ie no blown fuses...
when i got my corrado 6 months ago the spoiler worked fine then my son was showing his mate how it goes up/down/up/down...... on the swich and now it doesnt i have checked the fuses but they seem fine are there any in line fuses or could i be looking in the wrong fuse my car is a 1990 16v but the handbook is for a later car maybee the fuseboxchanged?
any ideas where to start would be great
