Stan 24v
Photo request!!! - LED GB Feeler
Anyone got any pics (and maybe sizes) of all the bulbs in the dash behind the clocks, and the floodlights? Im trying to get a deal sorted for a cheap package on these, but as my car is in the garage, cant take any pics.
may also be able to add the standard 3mm leds for the switches to the package as well :wink:
where can ya get the led's from, and can you change the colour of the computer etc too? wouldnt mind changin all mine to blue or summit, cant decide!
Apparently the top LEds for the clocks can be bought, but the bottom ones need soldering yourself, if you want to change them. Personally Ive kept the bulbs and just put different film over the mfa clocks.
So if I ask for the top 3, and then 25 3mm 12v LEDs for the dash, and see what package he'll do, then if you need more 3mm LEDs you can just order more.
Seem ok to you lot?
Oh, would you also like some LED bulbs for the interior lights ie main light on roof when door opens?
Give me any suggestions, and preferably the type or part number of the bulbs you want to replace, and I'll see what they'll do for us.
Supercharged, What size and type are the bulbs from the top of the display? also are the mfa etc ones the same?
Ive been looking into buying a pack to do this to mine, but have held off because people seem to be saying that the blue isnt bright enough. Is there a sollution to this?
as far as I am aware you are not to use films over the top of LEDS to change there colour, the emit light of a very specific wavelength, which means that putting a filter over them just makes them go dull.
I was told this after I had pissed about with my rear light on my bike using white leds with the red lense, it just went some shitty dull pink colour. After I fitted red leds it was incredibly bright
But LEDs are a directional light source so you end up with 3 bright patches rather than one glow. Supposedly roughing up the bulb with some fine sandpaper diffuses the light. Has anyone got these installed and are happy with the brightness?
I got some 4500 red leds and have to resister them lots they where way to bright in the switches, 4k7 resiters I think, but they are still a touch too bright
The film I have is over the original bulbs, not LEDs.
You can actually get wide angled LEDs too, or as above sand them a little. Apparently you can also put some clear setting glue on the tops of them to dispurse the light??
