1Gav 0 Posted December 7, 2005 the rear glass is easy enough to get out, you just need the right cutting equipement. I mean, tailgate glass. Otherwise it'd be refered to as the rear quarters. By the way, make sure you treat the rust otherwise it'll just come back. Quote Share this post Link to post Share on other sites
Taggart 0 Posted December 7, 2005 I was just gonna file/sand it, is it worth using Kurust as well? Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted December 7, 2005 xbones said: So I can just pull the rubber bit off round my rear window and it'll go back in easy? I've got a bit of rust developing under the rubber I want to get sorted ASAP. Yep....it might not go back in 'easy' though! Just yank it out and fill the gap with some B&Q mastic :-) Quote Share this post Link to post Share on other sites
Supercharged 2 Posted December 7, 2005 Quote Yep....it might not go back in 'easy' though! Use a bucket of warm soapy water and be careful not to twist it where it's joined (a weak point) Quote Share this post Link to post Share on other sites
gsbellew 0 Posted December 8, 2005 CorradoVR6-n.o.s said: depends what will happen to car in workshops and the standards of the repairer,if it is properly masked off it will be fine from overspray,grinding ect... Depends on my standards so, seeing as I'll be the one working on it :wink: Cheers for all the replies & help 8) Quote Share this post Link to post Share on other sites
PhatVR6 0 Posted December 29, 2005 I took a side window out today, that I was going to put into mine. then I realised...I hacked through the seal on the window I wanted to use, not my old one.durrrr. Quote Share this post Link to post Share on other sites
