johnxl1s
how much/head gasket.
I think a full head gasket set will set you back about £90 with Awesome
Hi there
Every Garage is different in there pricing it can range from £200-500 !! :shock:
You need to shop around.
Find out how good the garage is in workmanship,try to get recommendations from friends ect :)
Cheers James
dont get fleeced for parts..vw gaskets are cheep,my 1.8 one was £10 ..pattern bolts £35 ....its not a hard job cant any freinds do it for ya?
Parts are cheap,labour isn't
Its not what I call an easy job,waterpump and cambelt get replaced too,the head will be skimmed and new steam seals fitted and it wont just be a headgasket they buy in it will be a head set and its more then ten pounds!!
This all depends on the garage that takes on the job.
But were i work we do the lot.
