Stan 24v 0 Posted December 15, 2005 My drivers door rubber is slightly coming away from the window. Its the part towards the rear of the drivers door that the window slots in to. Its not quite flush all of the way down and it causes a draft. Its hard to say more than that without a pic, sorry. I havent got the car at the mo. Anyone know what Im talking about? Can you offer some advice? Does it roll back around towards the window? PS if someone has a close up of a door, I can circle the area I mean :wink: Quote Share this post Link to post Share on other sites
Stan 24v 0 Posted December 15, 2005 Got a pic. Its as if its peeling/rolling away from the window, as if being caught in the wind, if that makes sense :? Quote Share this post Link to post Share on other sites
Supercharged 2 Posted December 16, 2005 There is a metal strip underneath that goes rusty and may distort the rubber, I think you can remove it and hammerite it but i've not tried... The seal itself is £110 + vat from VAG! Quote Share this post Link to post Share on other sites
Stan 24v 0 Posted December 16, 2005 Do you know anyone who's done it mate? I defo not paying the stealers £110!!!! Quote Share this post Link to post Share on other sites
booted 0 Posted December 20, 2005 just had to renew mine after some S#*t nicked my sterio . was worth all of £5 the rubbers have a thin strip of adhesive (double sided tape?) that sticks it down on the inside of the door bit fiddly getting it in the correct position but the window channekl holds it in from the outside , sounds like yours may have a tear got my new original rubber from GPC about £50 Quote Share this post Link to post Share on other sites
Stan 24v 0 Posted December 20, 2005 Did you fit yourself mate? Was it fairly easy to do? Quote Share this post Link to post Share on other sites
booted 0 Posted December 24, 2005 yes the hardest bit was straightening the fraME WHERE SOME LITTLE t~~~SER stuck his screwdriver in just take your time Quote Share this post Link to post Share on other sites
