racingswamp46
Power surge???
My vr6 has been playing up for a while now, it has what feels like small power surges when you accelerate! i have changed the plugs and the airfilter and hosing. it has cams fitted so you would expect a power increase at higher revs but this problem comes right from the bottom of the rev range all the way to the redline! can anybody suggest what it could be coz its really starting to bug me?!?! HELP PLEASE
Agree with above... Take it to a VR specialist who will plug your car into VAG COM and diagnose any sensor faults straight away.
turns out the coil pack has a crack in it and needs replacing, along with the leads, and it needs a new cam sensor! about £350 they reckon to fix it! one good thing though it did put out 243bhp on the rolling road! chuffed with that!
here's the spec list, i brought it from a mate who used to use this forum he used the name vr6220, ihave just changed the alloys to brock b2's with deep polished rim because i bent one of the oettinger ones and couldnt get hold of any new ones! most of this work was carried out in the factory when the car was brand new, i have over 40k's worth of reciepts for it!
oettinger 3.2 engine conversion
two highlift camshafts
modified inlet manifold
modified exhaust manifold
modified air flow
oettinger chip and ecu
full powerflow s/s exhaust
de-catted
oettinger bodykit
oettinger type m alloy wheels
spax suspension shocks and springs (30mm front 20mm rear)
oettinger steering wheel
light smoke window tints
full cream leather retrim
additional instruments (volt meter, oil pressure)
and a private plate to top it off!! C6 RDO
Nice! You should post some pics up in the members gallery, would like to see the beast! :) 40k worth of receipts it ought to be pretty good... does that include petrol?!
its well thirsty on petrol! if you type in oettinger in the search part of the website then click the post from vr6220 there are some pics of it there, but this was before i got it and it still has the old rims on it and original number plate! still get the idea though!
Ah yes, I remember now there was a big debate about this car when he sold it, he was changing it for an escort... Anyway i've taken it OT :oops:
Off Topic, which is exactly where this has gone! :)
I reckon it could probably be locked up since the original problem has been diagnosed...? :wink:
i took the car to Clive Atthowe tuning in Norwich! apparently he's the best in the county for that sort of stuff. Anybody else used him before? he seemed pretty switched on.
