Ka`
Quick Help Needed
Hi,
I am currently outside butchering the car, and I can't get the ECU connector off the unit so that I could swap it with another one. Can someone please tell me whether it's supposed slide, lift, what? And what's the best way of doing the aforementioned motion *ooer*
Cheers,
Rica
There should be something that slides out of where its connected (it's locked in place), then you just pull it off...
Cheers for the answers so far,
Is anyone able to provide a quick pic?
Cheers,
Rica
Thanks all,
This can be locked, if threads are locked in Engine Bay. I figured out where I am supposed to pull as per triggermyson, the brittle plastic broke! With some ingenuinety and needle nose pliers, I managed to get the tabs pulled and the connector popped out. Now to replace the tabs at some point.
Cheers,
Rica
