dannyc
no go...
ayup geezers
my c isn't starting :mad: i think it might just be a relay but i thought i'd run it past you lot.
when i turn the key all of the igition lights come on and i can hear the feul pump prime but the engine dosen't start. the engine dosen't even get a chance to start.
any ideas which relay it will be?
cheers :)
Just under £25 from VAG... 8) DON'T buy the GSF / ECP cheaper ones 'cos they're crap and will break again...
saw something a while back on here somewhere about a thing you can make out of some wire and connectors that you plug into the plug at the back of the ignition switch and it sort of hotwires the car. do a search and try and find a link that would be an idea then you would find out if its the switch or not.
