greenbeltvr6 0 Posted December 27, 2005 As the title says, can I put my old bassy ported hifi speakers into the c, powered by the rear speaker cables? I intend to remove the tweeters and just use the woofers from ex hifi speakers? Quote Share this post Link to post Share on other sites
gradeAfailure 0 Posted December 27, 2005 car speakers are 4ohm, whereas home hi-fi tends to be 8ohm, so you won't get as much oomph out of them... Quote Share this post Link to post Share on other sites
greenbeltvr6 0 Posted December 27, 2005 So could I put both sets of rear wires into each connection on one woofer? I'm pretty poor on car audio- obviously! Just lookin 4 cheap method. Quote Share this post Link to post Share on other sites
gradeAfailure 0 Posted December 27, 2005 I have a set of JVC 6x9s with no grilles that you can have for a fiver plus the postage if you like?! Quote Share this post Link to post Share on other sites
Valerian 0 Posted December 27, 2005 depends on what car stereo you have ....most will take 4 to 8 ohms these days. You may find just using the woofers sounds rather flat ....i'de recommend fitting the tweeters and if poss the crossover as well Quote Share this post Link to post Share on other sites
greenbeltvr6 0 Posted December 27, 2005 Crossover? Quote Share this post Link to post Share on other sites
gradeAfailure 0 Posted December 27, 2005 Stops the tweeters getting the low frequencies and the woofer getting the high ones, if it's a proper 2-way crossover... Quote Share this post Link to post Share on other sites
steveo29 0 Posted December 27, 2005 if you insist on using your home stuff...id leave the speakers in the cabinets they came in, theyre made to work in a box , and will have all the x overs built in if you take em apart and run no x over the woofer will be trying to play high freq that the tweeter played Quote Share this post Link to post Share on other sites
greenbeltvr6 0 Posted December 27, 2005 Thanks for the advice guys - was gonna rip the 'crossover' out and wire straight from the connection plate into the woofer. I'll leave the thing in and see how it sounds... Quote Share this post Link to post Share on other sites
VR6 0 Posted December 27, 2005 I going to assume that these aren't going to be mounted in the engine bay, and move this thread ;) Quote Share this post Link to post Share on other sites
_Monkey 0 Posted December 27, 2005 To be honest mate, i'd probobly take gradeAfailure up on his offer. House speakers were designed to go in the house, not in the car. Have you ever looked at the wattage of house speakers compared to the wattage or car ones? House spaekers usually start from around 50 watts and when you turn them up you have the neighbours complaining (from Alaska!) Whereas 50watt car ones, you'll be hard pushed to catually hear. As discussed, this is partly due to the ohmage but it also has a lot to do with the resonance of the car, everything vibrates in a car which saps A LOT of sound. If you run the house speakers, you'll end up damaging either the head unit (won't like the ohmage from the speakers) or the speakers(won't like the wattage from the head unit). Quote Share this post Link to post Share on other sites
greenbeltvr6 0 Posted December 27, 2005 Already pm'ed gradeAfailure, in anticipation of total project failure. It's one of those things when you know it'll go wrong but do it anyway to see what happens :) I just had these speakers lying around... Quote Share this post Link to post Share on other sites
_Monkey 0 Posted December 27, 2005 Good Man! You don't learn anything without trying! :wink: Quote Share this post Link to post Share on other sites
catch_twotwo 0 Posted December 28, 2005 I reember doing this exact same thing on my first car and it sounding a bit rubbish. Then again it's all down to the headunit and mine was about 10 years old and looked on it's last legs at the time..... Remember.... bootsales are your friend when it comes to cheap car audio. It's amazing what people will rip out to replace. Quote Share this post Link to post Share on other sites
colinstubbs 0 Posted December 28, 2005 The other prob with using hifi speakers in a car is that they're not designed to cope with the extremes of temperature and humidity that occur :wink: Quote Share this post Link to post Share on other sites
