FTM1975 0 Posted January 5, 2006 Recently the intermitant wipe on my C's wipers has stopped working. It used to work but even then seemed very random!! Now its just stopped all together. Anyone got any ideas????????? Quote Share this post Link to post Share on other sites
Jim 2 Posted January 5, 2006 Do the wipers only work on one speed setting too - ie the fastest one? Quote Share this post Link to post Share on other sites
FTM1975 0 Posted January 5, 2006 No they seem to work on both speeds. to be honest I generally tend to avoid using the wipers at all costs as the so rubbish anyway! Quote Share this post Link to post Share on other sites
dazzyvr6 0 Posted January 5, 2006 sounds like the relay has gone for the intermittent wipe,and you say the wipers are rubbish,have you not changed over to the lupo set up yet? Quote Share this post Link to post Share on other sites
Jim 2 Posted January 5, 2006 Hm.. if it was only working on the fastest wiping speed i'd have said the relay was to blame. Still might be worth pulling the relay and reseating it just to make sure - that fixed my wiper problems! Quote Share this post Link to post Share on other sites
FTM1975 0 Posted January 5, 2006 ok nice one i will take a look Quote Share this post Link to post Share on other sites
Not_Aircooled_or_Taxfree 0 Posted January 5, 2006 Hm.. if it was only working on the fastest wiping speed i'd have said the relay was to blame. Still might be worth pulling the relay and reseating it just to make sure - that fixed my wiper problems! Jim, where is the relay located and what does it look like. i have the same problem. Ta! Quote Share this post Link to post Share on other sites
trev-b 0 Posted January 5, 2006 Is the wiper relay in the fusebox? Quote Share this post Link to post Share on other sites
Supercharged 2 Posted January 5, 2006 Is the wiper relay in the fusebox? Yep, if you have variable intermittent wip then it's alot bigger than the other relays to spot... Quote Share this post Link to post Share on other sites
Jim 2 Posted January 5, 2006 What he said :) I can't remeber which relay it was to be honest as it was in 2004 that I had the problem! And my memory is awful at the best of times. Quote Share this post Link to post Share on other sites
