TITAN 0 Posted January 11, 2006 Can anyone help!! my spoiler was seized so i stripped it all down lube the and freed off cable wired the motor up to a battery and all working fine. refitted it wired it all up but dose not work of the switch i have left it at this as i ran out of time not looked at it since ,So wat is the next step?? fuse ? check feed to switch ??? Thanks !! :mad: Quote Share this post Link to post Share on other sites
Trig 0 Posted January 11, 2006 I'd of checked the fuse first I reckon! Then check the switch. :) EDIT: Does it work automatically? Quote Share this post Link to post Share on other sites
TITAN 0 Posted January 11, 2006 No not working at all ill have a look let you no wat speed it set to work at 40mph ??? Quote Share this post Link to post Share on other sites
vwdubs 0 Posted January 11, 2006 If you do a search its fuse number 16 that may have blown, this has been discussed shed loads of times as mine is still not working by manual or auto, next check is power getting to motor and the motor for me. Quote Share this post Link to post Share on other sites
TITAN 0 Posted January 11, 2006 Thanks ill check this. When you say is it working automatic do u mean when the car hit the right speed? and manual when you can winde it down yourself? or from the switch? Thanks Quote Share this post Link to post Share on other sites
selbekk 0 Posted January 11, 2006 I believe he means by switch. If you can't wind it down manually, something is seriously wrong with the mechanism. Try to switch the spoiler control box with a friend's, perhaps that can be the problem. Check for corrosion on the contacts, and if there is good contact between the loom and the control box. Quote Share this post Link to post Share on other sites
VR6 0 Posted January 11, 2006 Moving to Exterior. Quote Share this post Link to post Share on other sites
TITAN 0 Posted January 11, 2006 No i can move the spoiler with the winder .ok thanks for all your help ill keep u updated Cheers all :lol: Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted January 11, 2006 what if youve crashed and its stopped working due to that. Bumped front pass corner of car. not that bad. When i got home i made sure it worked. Was able to put it up using the switch, but it wouldnt go back down. Now it doesnt work automatically either. If the fuse is ok, what next? Is it possible for the shock of the crash blowing something??? Quote Share this post Link to post Share on other sites
TITAN 0 Posted January 11, 2006 If the fuse is ok then is poss somthing els because the fuse will make a the connection and also you say the switch lets u put it up but not down so not a blow fuse. i need to check mine fuse and switch plus am going to get a test light and go through the system. :!: Quote Share this post Link to post Share on other sites
TITAN 0 Posted January 13, 2006 Right sorted it after fitting it all back, fuse was blow fitted new fuse work s fine. thanks for all your help Cheers. Quote Share this post Link to post Share on other sites
