matt_corradovr6
headlight bulb replacement
can i get away with taking the air box out to replace the bulb in my vr6 rather than having to fiddle around taking out the whole unit??
plus how much for new front fog light and where from as a pheasant decided to smash mine with its head. the corrado won, just! :(
I did my sidelight on that side the other day and just took the airbox out.
After I reckon I could have done it without removing the airbox, but it only takes minutes anyway.
Take the headlight out mate.
About £90 for a fog light from the dealer i think! GPC or Vagparts prob get you the unit cheaper. Or you can get a lens from the usa and just replace that with a bit fiddling. Post on this in the search, but i think Kevs done his and others.
VAG - I think they are about £30 each, or put a wanted ad up and check to see if anyone is breaking a car. There is a difference between early & late ones I think.
