B DUB
G60 VERY ILL please help
hi ive got a corrado g60 and have recently changed the fusebox .which was in fine working order but now the car has started dieing out when i get to high revs in 3rd gear and as soon as i put it in5th gear . changed the leads /plugs / and dizzy cap which were suggested but still the same . CAN ANYBODY HELP PLEASE ?
checked all connectons and are all fine. like i say was going ok for a while aftr i fited the box in then allof a sudden it cuts out and also set of the blimey alarm when i get into high trevs in 3rd gear and as sonn as i put my foot on the excellerrator in 5th .
what do u mean by the gear stick hitting the wires WALESY .I f u can explain as a aint a clue .is it something i can do or is it a garage job??? cheers.
this will sound stupid but where shall i look ? under the car?under the bonnet ? or dismantle the housing un the car around the gear stick ???
sos lads i aint a clue what to look for
B dub i think you'd be better taking it down to darren!
he's the G expert amongst! us if you look further up this thread his name is g-man and his address & phone number are on there just give himn a ring his site is
http://www.g-werks.com his name is Darren
Cheers Andy
Did you touch anything else when you replaced the fusebox or since you replaced the fusebox? anything you have fitted, replaced anything unrelated?
Jay
sorted now mate it was the gear linkage hitting a live wire and cutting the engine out ...cheers anyway.
