iflorey
Late clocks Early corrado
Hi Guys
Does any one know how to fit late clocks into an early 16v corrado?
And does anyone know where i can get some of those chome rings that fit round you clocks.
Thanks
Ian
Ps
I will be posting some new pics of the rado soon with audi RS4's!
Be very carefull when fitting those rings,the instructions say that you should remove the plexiglass front cover using a stanley knife to cut around the glue,bad move,as soon as i breathed on it it cracked but luckly i've got a few spare,not as easy as they make it out to be...
agreed! same here. best stick the to the clock face if you can.. Im still looking for a new clear plastic front for mine
edit: you should have no problems fitting the clocks but you may need a speedo sender as early cars had cables.
