Bobert healetty
just got my rado heres alot of pics
here is a list of stuff that has been done to the car before i owned it and just recently before i purchased it (just picked it up last night(pics to follow)
new ac compressor
new ac dryer
new auxiliary fan assembly
new starter
new cv axles
new sunroof seal
new brake pads
new cross drilled rotors
new exhuast
new exhuast manifol
new harmonic balancer
new engine mounts
new battery
new distributor cap and rotor
New 180ºF thermostat
new window regulators
all exterior and interior trim replaced with new
all dents and dings repaired and car was resprayed factory blue
BLock:
recently rebuilt short block
new Pro Power forged Aluminum 83mm pistons
new forged connecting rods
new connecting rod bearings
bored cylinders
Head:
Cleaned
ported
polished
new 268º camshaft and sprocket
5 angle valve grind
new lifters
42mm intake valves
35mm exhuast valves
titanium valve spring retainers
heavy duty valve springs
ported intake manifold
port matched throttle body
engine oil seals replaced
ARP head studs
carrera coil overs(?????)
neuspeed front sway bar
neuspeed rear sway bar
neuspeed rear tie bar(???)
neuspeed oilpan
neuspeed injectors
neuspeed spark plug wires
Eurosport intercooler piping
New adjustable FPR
New Authority stage III E-PROM chip
brand new 17" enkei RS-5's
with 205-40-17 fuzion tires
this car dynoed at 215hp at the wheels and 210ft lbs of torque at the wheels(when the supercharger was installed) but since the charger is blown its being sent off to kompressor kanada for there stage 4 rebuild and a 65mm pully
and the pics
You're sending it for a stage 4 rebuild :?:
Can't quite tell from the pics but looks like it's already had some work done so might only need a rebuild.... No point in wasting you're cash....
Looks very nice (apart from the grille), is the petrol flap a different colour or is it just the light. Like the RS5's, they suit the colour. Not sure about the steering wheel either.
the steering wheel just has some leather cover over it i will be replacing that along with the grille....the petrol door is just carbon fiber so yes it is a different color
i have no idea if the supercharger has had work done...so maybe i will just get the standard rebuild?
update...
the supercharger has previously had a stage 4 rebuild...the only problem with the charger was one of the oil seals on the displacer was never replaced when it was last rebuilt...but i will rebuild the whole thing anyways..i cleaned the entire charger with brake cleaner once i got the displacer off etc and the thing is shiny as a mother * looks like lots of porting has been done etc.. everything is in mint condition...no knicks chips, scratches etc other then all the little circles etched in from the displacer it looks brand new...the only thing that sucks is i have to get a hold of a press somehow to get the bearings out...and i also cant get one of the keys off to take the main rod out...the biggest key is stuck on i tried pliers, vice grips, screw drivers etc the thing wont budge..the other two keys came out very easily...i was thinking on just replacing the one oil seal on the displacer (cause thats the only thing wrong with it and the only thing leaking oil) but i guess since i already have the rebuild kit i may as well just rebuild the whole thing...
