**Ian** 0 Posted January 26, 2006 (edited) I could really do with a picture of a fusebox off a 1991 G60, I am not sure if my relays are in the right order as mine is getting converted from a 16v to a G60 so there might be a difference in relay positions? + I have a spare relay holder loose above the fusebox with 2 of its 4 wires cut. It has a brown wire(cut) a green(cut) a red/white wire and a red/yellow wire coming out of it :? Edited March 27, 2011 by Supercharged Title change to aid searching Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted January 26, 2006 Ian Ill try get you a pic of the fuse box tonight, if not, tomorrow. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted January 27, 2006 This any good... Quote Share this post Link to post Share on other sites
**Ian** 0 Posted January 27, 2006 Quite different to mine :? I dont have a relay 80, have VW replaced it with a different numbered relay or did the 16v never have relay 80. Its a shame he didnt swap the G60 relays over before selling me the car :( Quote Share this post Link to post Share on other sites
iow_corrado_g60 0 Posted January 27, 2006 supercharged is that exactly what they should look like or have you changed yours at all Quote Share this post Link to post Share on other sites
**Ian** 0 Posted January 27, 2006 Cheers mate that very helpfull, but whats the one above number 53, there is no number on it :? Quote Share this post Link to post Share on other sites
Supercharged 2 Posted January 27, 2006 Thats from a 92 G60 - the one above 53 is the ECU relay I think, 80 is the Fuel pump relay... Quote Share this post Link to post Share on other sites
Yandards 0 Posted January 27, 2006 Ok, After looking at my wiring diagram manual for the C relay in position number 12 (So the relay with 80 on it in Supercharged's pic) is the fuel pump relay - this can be numbered 67 or 80. The two relays number 53 in the pic are in positions 10 and 11 and are for the two tone horn. The relay numbered 99 in the pic should be numbered 19 according to my info and is for the wash wipe - this is in position 8. The relay numbered 21 in the pic is for the emergency light (Hazards) and is in position 6. The relay with no number on it should be numbered 18 and is for the X contact, this runs things like the air blower, heated rear window and windscreen wipers. The relay numbered 30 in the pic is for the digifant control unit and according to my manual it should be numbered 53 and is in the number 3 position. The relay numbered 72 in the pic is for the intermitant wipe on the front and rear windows. This is all taken from a UK VW electrical manual for the Corrado but I don't have any updates hence the differing relay numbers. Quote Share this post Link to post Share on other sites
iow_corrado_g60 0 Posted January 27, 2006 heres mine looks different mine 91 g60 Quote Share this post Link to post Share on other sites
24V Renshaw 0 Posted January 27, 2006 Looks the same apart from being able to see the central locking/window relays. Jay Quote Share this post Link to post Share on other sites
iow_corrado_g60 0 Posted January 27, 2006 jay whats the 99 one for then instead of the 91 or is this no different? Quote Share this post Link to post Share on other sites
Yandards 0 Posted January 27, 2006 The relay numbered 99 in the pic should be numbered 19 according to my info and is for the wash wipe - this is in position 8. Ahem.. :wink: Quote Share this post Link to post Share on other sites
iow_corrado_g60 0 Posted January 27, 2006 sorry yanyards i didnt actually see your first post! do you know where the relay for the lights should be? have heard its behind headlight and in front of the battery but i posted pics on other post as i couldnt see them well the didnt look like relays Quote Share this post Link to post Share on other sites
**Ian** 0 Posted January 27, 2006 Heres a piccy of mine, I think its all in the right order apart from needing another 53 on the bottom row, I have a extra relay holder next to 90/06 relay, whats it for? Quote Share this post Link to post Share on other sites
**Ian** 0 Posted January 28, 2006 If thats right there must be another problem as I still have no spark :x Quote Share this post Link to post Share on other sites
