bristolbaron 11 Posted February 3, 2006 Hi guys, sure the answers here some where, but checked the wiki and search, but no joy so far.. I have a set of 17x7.5" wheels that need tyres, and thought they would need to be 205/50/17.. however, as ive been looking around, it would appear that the tyre is too deep. Can anyone guide me in the right direction? I want a slightly stretched look, and would rather not roll the arches for now if i can get away with it! One thing im slightly concerned about, is a link from the wiki gave me this information... Your new wheel will have the following chracteristics: The clearance from stut housing to the inside of the wheel will be THE SAME The outside edge of the wheel will EXTEND an extra 26mm Your new wheel will have the following chracteristics: The clearance from stut housing to the inside of the wheel will be THE SAME The outside edge of the wheel will EXTEND an extra 26mm Do i have to worry about the extra width? Also, as im probably in trouble for posting without finding something from the search, does anybody recommend a particular tyre/supplier for what ill be after? Thanks in advance, Baz. Quote Share this post Link to post Share on other sites
W3RKD 0 Posted February 3, 2006 205/40/17 will be perfect Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted February 3, 2006 Yep, 205/40/17 is what you need. 50s will be massively oversized. Some tyres are broader shouldered than others. I've had 205s that look wider than 215s! Just the luck of the draw really. The 205 section F1 sits perfectly on 7.5s if it's any help. Quote Share this post Link to post Share on other sites
Dirtysouth 0 Posted February 3, 2006 toyo and uniroyal are ok too have both on mine running 17x7.5 Quote Share this post Link to post Share on other sites
bristolbaron 11 Posted February 3, 2006 cool, 40's it is then. Ive had F1's before on my old polo in a 195/45/15, and found them scary when cornering. that may have been more to do with the car though? Quote Share this post Link to post Share on other sites
Furkz 0 Posted February 4, 2006 some ppl use 195/40/17 for a stretched look if thats what your after otherwise 205/40/17 will be fine Quote Share this post Link to post Share on other sites
bristolbaron 11 Posted February 4, 2006 and i shouldnt have a problem with the wheel width? Quote Share this post Link to post Share on other sites
