reaper1_3
Fitting those TT seats....
hi all i am currently getting alot of people asking about fitting TT seats....
So if the mods are happy could you make this a sticky??
here goes....
I have included photos also to help get the idea....
basically the subframe spans the gap between the original rado runners and gives you a rear mounting point for the tt seats.
as you will have seen the tt mounts are horizontal and the rado vertical...
once you have the frames built up you will need to drill two holes to allow you to bolt the frames onto the tt runners when done you will be able to slide the tt seats into the original rado runners.
when happy with the position you will need to drill two more holes into the cross member which runs across the rado foot well ( basically either side of the original seat hook up point.)
ok hope you are following this......
remove tt seats you will see at the front of the tt runners the original front bolting points these will be at a 45% angle to the runners. I decided to flatten these by cutting the folded down sides off and hammering them flush with the runners hence allowing me to bolt them into the cross frame either side of the original bolting point in the front foot well.
i refitted the seats and marked the cross member then drilled the holes.
heres the only tricky bit the cross members has some small holes inthe top which you will have to hold the bolt through, i decided to remove seats and with some metal glu glue bolts to the underside of the frame positioned directly under the hole i just drilled. let the glue dry and refit seats you can the bolt the front part of the tt runners into position.
and thats it LOL
i hope you can understand the above basically it took me a day to fit both, but that was obviously working everything out!!!
if you need any help pm me and i will send you the plans for the frames....
Thanks for the write up Reaper :)
Much appreciated.
However, we are starting to add guides such as these to the Wiki instead of having a stack of sticky threads.
If you pm or email this info and pics (or just the link to this thread) to Dinkus or Trigger, they'll add it to the Wiki for you.
Any probs, drop me a pm.
