exturbo2003
window switches early/late
has anyone converted early window switches to the late type and if so do you have a wiring plan to connect the early loom to the newer switches
thanks
When doing this me and Chris (Shilakadaddy) just soldered the early wires to the wires on the back of the new switch, they're all the same colour. Its easy enough to do.
If you don't have the later loom, the earlier plugs actually fit straight in apart from one pin which you can just put a spade terminal on. Not ideal but you can do it. I did before i got MK4 ones.
jay
