pkripper
strut rubbing on 9's at the back
bought some new wheels 16 x 7.5 et 20 on the front and 16 x 9 et 15 on the back, am i going to have issues in terms of the wheel hitting the strut bearing in mind i am lowered 60 mil on a spax kit not coilovers.
just occured to me after reading some old posts via the search.
cheers
Matt
Should be fine; Laura (scarlett) is running 9x16 ET15 at the back, lowered around 50mm on non-coilover suspension... :)
Thanks thats a relief.
You need the ET 15 to clear the strut its the arches that should concern you.
not all the time unfortunately... some still require a bit of a spacer to assist
Im not heavily into the stretch tyred look but will obviously need to go as low as possible to minimise rubbing. whats the best i can hope to get on 215 x 40 maybe 225 x 40
215-35-16 matthew ...
he said hes not into the heavily stretched look...[/quote:bfaa0]
you know as well as i do that to put a 9" on the back of a corrado correctly you need to stretch the tyre mate.. Remember what you learned about simply attaching a wheel or correctlly fitting one ! :wink:
he said hes not into the heavily stretched look...[/quote:1db3e]
you know as well as i do that to put a 9" on the back of a corrado correctly you need to stretch the tyre mate.. Remember what you learned about simply attaching a wheel or correctlly fitting one ! :wink:[/quote:1db3e]
you know full well i agree with that sizing,,, but not everyone wants to pay abt £85+ per tyre and wants the same look,,, although its correct 8)
that seems a rare tyre size, who makes them darren?
:wink: the rear of a Smart Crossblade runs these tyres as standard. :wink:
he said hes not into the heavily stretched look...[/quote:85d37]
you know as well as i do that to put a 9" on the back of a corrado correctly you need to stretch the tyre mate.. Remember what you learned about simply attaching a wheel or correctlly fitting one ! :wink:[/quote:85d37]
you know full well i agree with that sizing,,, but not everyone wants to pay abt £85+ per tyre and wants the same look,,, although its correct 8)[/quote:85d37]
Indeed but i know matthew like to do things correctly :wink:
so daz will it be correct to say that the 195/40 size is from a smart car too' date=' FR wheel[/quote']
Indeed you are learning young JEDI
