mtc R32
Interior Help
What i neeed you fello dubbers to tell me is, whats the difference between an early spec interior and a late spec interior. I'm buying a 94-plate Vr6 Rado and have seen the leather interior on ebay forsale. Reading through the thread someone has suggested that it may be an early interior as its coming out of a G60.... Will it still for or will it look naff.
All G60s had early interiors, the difference between early and late interiors is the dashboard switchgear (early is mostly from Passat, late is Corrado only), heater controls (early is like MK2 Golf, late is like Passat), sunroof switch and interior light (early is from Passat B3, late is Passat B4), and the front doorcards (early has Passat B3 window switches in the card itself and Passat-style mirror switch in the card, late has Passat B4 window switches mounted on doorpods and MK3 Golf-style mirror switch mounted in the grab handle).
If you're looking at that interior on eBay, the only different parts will be the front door cards, but imho it'd look poo to change from late back to early...
