leew
Windscreen wipers are pants!
Dremmel Mod, did it worked for you?
12 members have voted
  1. 1. Dremmel Mod, did it worked for you?
Can anybody recommend some good windscreen wipers\blades. The wipers on the C i just bought are absolutly pants, dangerously so :(
I'm sure everyone on here will agree with you. It's a common fault with the C.
There are a couple of things you could do.
1. Modify the wiper arm stops by grinding off material to force the wiper arms on to the windscreen. (detailed explanation can be found on the CCGB website)
2. Get hold of the Lupo GTI set up. (can be found on here under the Tuning & Mods section)
I did the first item & it does work. I also use Rain-X on the windscreen from time to time.
Read Here http://corrado.atx-hosting.co.uk/viewtopic.php?t=153
This is the best mod by far
Then add one of these
http://www.corrado.atx-hosting.co.uk/viewtopic.php?t=336 and your sorted
Dont bother trying to mod the present wipers and arms, its a short term solution that is a waste of time imho.
hello, well i have had the same problem as eveyone else but did not need to go to any extremes apart from buy the more expensive Bosch wipers from halfords (drivers side has the spoiler) and i have not had any problems with them since!!!
Your very lucky then, mine are the same expensive ones and jump spear at speed!!
I will be too :)
Just need a job first.... :roll:
I done the dremel mod and it didn't work. To be honest, I did rush it a bit and it is tricky to do it right. I decided to take another little bit off the second time.
This along with a slight bend on the wiper arm and Bosch blades (both having spoilers) done the trick :D
Happy Days
Didn't use the voting buttons coz you haven't got a sort of option....
Did the dremmel bit on both motors and it did improve them. Trouble is the wipers now 'hang' on to the glass on one of 'em unless its really wet, p'raps I cut too much off
Haven't decided on the lupo yet, not sure about the curve on the drivers side - need to see in the flesh first I think
