booted 0 Posted March 10, 2006 can anyone tell me the min ET i can run on my 16v ? i fancy a sert of audi wheels(possibly TT) but im not sure if they will fit as i will need 4x100-5x100 adapters i would be looking to use 205 or maybe 195 tyres cheers Quote Share this post Link to post Share on other sites
Furkz 0 Posted March 10, 2006 195 you may get away with it,,, i think the fronts maybe slightly out the arch with 205's Quote Share this post Link to post Share on other sites
cheesy 0 Posted March 10, 2006 You wouldn't be able to do it as the et would be very low If ya want tt wheels, look at fitting the hubs etc from a vr to use 5x100 chris Quote Share this post Link to post Share on other sites
gradeAfailure 0 Posted March 10, 2006 Hasn't G60BV got TT Comps on his G, running adaptors? Quote Share this post Link to post Share on other sites
Furkz 0 Posted March 11, 2006 it can be done and seen it done... was actually going to do the same at one point,,, and if you realyl are scared of the low offset you can always get custom adapters made up with a min thickness of 17mm,, which would enable you to run 7.5J wheel at ET 21 which would be perfect... i run 7.5J wheel with ET15 and the wheel sits inside the arch with absoluetely no rubbing with 195/40 tyres cheesy you must have been using 205/40 tyres, if you are stating it cant be done... hub conversion is the most secure way forward though... but adapters can work Quote Share this post Link to post Share on other sites
booted 0 Posted March 11, 2006 Furk'z are your wheels 17's and have you done anything to the arches? Quote Share this post Link to post Share on other sites
Furkz 0 Posted March 11, 2006 the wheels currently on the car are 16" Quote Share this post Link to post Share on other sites
