insomniak
My shopping list
Im waiting for my new toys - Silverline-X coilovers. when these arive I plan to do the breaks/bearing etc. at the same time (well not me but a mechanic friend of mine)
So far I have picked out the following from GSF
60200F BRAKE DISC-BREMBO'MAX' CO VR6 34.50 x2
60342 BRAKE DISC-REAR(5 STUD) B CO VR6 19.15 x2
64325F BRAKE PAD SET-PAG.FAST RD CO VR6 8/91 32.50 x1
64601F BRAKE PAD SET-RE FAST RD CO 9/88 26.50 x1
41224K WHEEL BEARING KIT-FRONT CO VR6 8/91 21.50 x2
41311K WHEEL BEARING KIT-REAR CO 9/88 6.75 x2
hopefully I have choosen OK. I also know I will probably need top mounts etc
anything else that I will definately need??
Thanks..
Have all my parts now, just waiting on my shocks to be delivered (end of the week). nice set of silverline x coilovers :)
couple of questions if I may??
GSF sell a braided brake line kit but the girl wasnt 100% convincing that this was for the corrado - tho it was for a VR6. Will this be alright for mine?? mine is a 92 VR6..
Also, can any one think of any other parts I may need prior to me fitting this lot.. (top mounts, spacers etc...)
You should have the top mounts (VAG are the best quality) and rear bump stops changed as well when doing the suspension
  Quote
Rear bumpstops should be already included in the coilovers (I've got Silverline-X's too)
So you're saying that you can get rid of the rear bumpstops if you put coilovers on? Never heard that before.
The goodridge kit says 'Corrado VR6' on it - the late Golf VR6 ones will not fit as they are for the 288 front brakes and therefore have the banjo connections.
  steve_16v said:
  Quote
No.. they are already on the pre-assembled coilover
  Quote
Aaah, mine never came with them (at least I don't think they did :oops: ), I take it the silverline x's are different to the highsports in that respect?
mine are due any day :) :) so Ill know for def if I need them.
Ill keep my order on hold untill I know.
VAG topmounts - dealer or GSF?
i was, but when i spoke to them, they where v v arrogant and unhelpfull. so ill b looking elsewher 1st b4 i try them again.
i wouldnt recommend them but as the only vw dealer-ish on the island my choices are limited.. grrrr :x
