Blinky16v
Help needed, low BHP figure
In one respect removing the differential pressure regulator would lose the acceleration enrichment
:oops: Ah sorry, should have explained better, you need to remove it to make the adjustment, then re-fit it.
The Charles Probst book is good, I agree. I have a technical book from Bosch about K-Jet, its only about 15 pages long, but gives a good explanation of how it works. Would love to get hold a copy for KE-Motronic.
One of the lads I used to work with brough a cheap chip of ebay for his M5. It threw a rod a couple of months later :shock:
As tehy say, you gets what you pays for.
Phil,
If the OEM chip makes no difference t the mixture it'll have to go back to Stealth to be sorted. I'm planning to do this asap, I'll let you know the results when I have them dude.
Don't suppose you wanna buy Blitz Chip do you? I've also got an eco-tek thing as well apparently good for 40+ BHP!! :)
Blimey craig!!! That must've p155ed your mate right off!!! Better get that blinkin' chip outta mine asap by the sounds of it!!
Blinky16v, No thanks, have a chip specialy programmed for the 9A by Bosch in mine :wink:
Maybe you need another eco-tek, I have one sat in my tool box, which you can have for a small fee. If you fit two, you could make 218.1bhp.
