Dec
Removing black plastic window trim
The small black plastic triangular bit behind the wingmirror.....this bit....(circled in the pic)
I've removed the obvious screw....but does this black plastic triangular bit just prize off with a screwdriver? Or is it screwed from the inside (doorcard off job?)
I'm sure there is a screw behind the black plastic trim inside(that just pops off)
Once you have removed the screw pull the trim towards the rear of the car because its hocked behind the door skin and pulling it forward will snap it off.
Hope this helps.
Cheers! thats what I was looking for!
Didn't want to be pulling it the wrong way and breaking the thing :wink:
