OrbitAl
Central locking query
Help if possible folks. Got a sigma cat 2 alarm/immob on C and recently the drivers door lock has stopped working from remote fob.All other locks engage from the fob and central locking still employs when drivers door locked with key.Any suggestions to remedy???? :roll: Thanks
sounds like the metal connecting rod (from central locking pump to door lock mechanism) may have popped off,or broken out of the plastic linkage.
im not too familiar with the set up,so having a bit of a guess.will be a door card off job to investigate.
Neil. :)
no probs m8 8)
if you just find the central locking pump (opening end of door) move your hand up the back of it and find the metal rod.it should be firmly in place,and you will be able to operate the pump by nudging it up or down.
if its loose and wobbly,then its probably come off up at the top.
did i say im not familiar with these? :? :lol:
Neil.
