billinjah 0 Posted June 20, 2006 brembo 305mm ibiza brakes porsche 5x130 bbs rs rims front 7" rears 7.5" rear et 0 for shows and 6 for go's! front et 4 195 45 16 all round although rears soon to be 40 profile (maybe!) Quote Share this post Link to post Share on other sites
iow_corrado_g60 0 Posted June 20, 2006 cheers lads i originally started this a while ago when i was looking fior a 2nd set of alloys keep em coming and ill update when get home thanks for everyones info im sure this will help someone Quote Share this post Link to post Share on other sites
jonrb 0 Posted July 5, 2007 There's something I don't understand about up-sizing the wheels and tyres. Everyone who is running 16's seems to be running 205/45 R16 but the various tyre calculators show 225/40 R16 as having a closer rolling circumference to the standard 205/50 R15. Is it a case that in the real world 205/45 R16 is more suitable than the on-paper figures would suggest? Tyre Size Comparison Tyre code Diameter Circumference Difference ---------- -------- ------------- ---------- 205/45 R16 591 mm 1857 mm 0.84 % 215/40 R16 578 mm 1816 mm -1.3 % 225/40 R16 586 mm 1841 mm 0.07 % Sorry to resurrect an old thread, but I'm moving nearer to making a purchasing decision and could do with an answer to the above. Forgetting about 225/40 R16 as I haven't seen anyone wearing those, I notice that a lot of people mention that 16's can be run as 205/45 R16 or 215/40 R16 It seems to me that if you're keeping the same width and rolling circumference (ie. 205/45 R16) then you're not going to gain much of an increase in contact patch, whilst the increased width of 215/40 R16 suggests an advantage. And yet a majority of people seem to wear 205/45 R16. Why is that? Edit: Is it because 205/45 R16 is a closer match to the rolling circumference of the original 205/50 R15? It seems to be +0.8% for the 205/45 R16 and +1.3% for 215/40 R16. But if that's the case then why not 225/40 R16 on 16x7.5 which is only a 0.07% difference? Quote Share this post Link to post Share on other sites
