Nick
Faulty Rear Light
My Drivers side rear driving light wont work. All the other lights and bulbs work fine though.
Ive replaced the bulb, twice. And even replaced the bulb holder unit, but it still wont work. I then plugged the light connector from the other side to the faulty one and it worked.
Any ideas?
is your headlight out on the same side?
either a fuse or a wiring fault,more likely to be the fuse.
Neil. :)
ahh right,mmmm. :?
so its just the sidelight that isnt working? the indicater/brake light etc all work fine on that side?
if so then its looking like a wiring problem.
i think? the drivers side unit takes power from the passenger side via a second plug (or the other way round),for the sidelight/reverse/brake light? maybe check the loom running across from the corresponding unit.
Neil. :)
