Ronan
Central Locking help needed
Right, I have a Toad Ai606 alarm, which has never played up but yesterday it started to - when I press the remote, the alarm arms but the central locking doesn't work. It also doesn't work if you press the passenger side locking pin down (the lock pin has been taken out of the drivers door), which means the passenger door is stuck shut now because I can't pull the pin back out!!
Does the central locking work off a fuse, if so I can check the fuses when I get home - if not, does anyone have any other suggestions?
There is a central locking fuse (no idea which one though i'm afraid!)
There's plenty on here to read on this problem, as i'm doing the same at the moment!!
So as they say 'Use the search'
Adam
At least your is consistant.
Mine locks perfectly, but sometimes after its left a while, doesn't unlock the first time but does if I lock and unlock a second time!
Bloody odd!
