s.g
head lights
this may sound dumb but whats the difference between LH and RH drive head lights, is it something to do with the angle of the light/lense??
yep :)
most of the time its the way the glass is cut on the lense.
hence why you can tape/block off part of a l/h lense and still pass an mot.
also,depending on the car they will mount in more of a lhd way,can normally use the adjustment to get around it (normally adjusted to somewhere near max)
neil. :)
thanks for the replys. as i will be taking these apart any way it means they will do nicely, bonus :cheers:
