Krazee 0 Posted April 13, 2006 Can one of you esteem gentlemen take a picture of maybe the bottom of your seat brackets, or link a photo if the brackets off the seat? I just picked up a pair, and would like to confirm that I have finally found a proper set. THANKS!!!! Quote Share this post Link to post Share on other sites
Krazee 0 Posted April 15, 2006 These are what I got...hope they are the correct ones: Quote Share this post Link to post Share on other sites
gaz the geezer 0 Posted April 15, 2006 hello Krazee, as it happens, i`ve got the seats out of my car at the moment, i`ll post up some pics in a few hours, hope they are of some use Quote Share this post Link to post Share on other sites
gaz the geezer 0 Posted April 15, 2006 these pics are of my passenger seat ( left hand ) subframe, i also found a sticker with the number 535 881 103b if it`s any help. Quote Share this post Link to post Share on other sites
A20 LEE 0 Posted April 15, 2006 These are what I got...hope they are the correct ones: they look like the right ones to me. Not sure if Gaz's are recaro's from those pics. Look like heat standard seats as i can't see a motor at the front of the subframe. Quote Share this post Link to post Share on other sites
gaz the geezer 0 Posted April 15, 2006 Not sure if Gaz's are recaro's from those pics you are right mate A20 LEE, standard seats..... didnt read the thread properly ...... well, it was early in the morning, sorry about that Quote Share this post Link to post Share on other sites
Krazee 0 Posted April 17, 2006 Lee.... How did you go about wiring these in? did you use the factory harness or did you hardwire them? Quote Share this post Link to post Share on other sites
A20 LEE 0 Posted April 17, 2006 Lee.... How did you go about wiring these in? did you use the factory harness or did you hardwire them? Hardwired them, going to fit the full factory loom and heated elements as soon as i find some for a reasonable amount. Quote Share this post Link to post Share on other sites
Krazee 0 Posted April 17, 2006 this might be a silly question...but how do I go about hardwiring them? Also...how can I just power the motor to make sure it is working? Quote Share this post Link to post Share on other sites
A20 LEE 0 Posted April 17, 2006 this might be a silly question...but how do I go about hardwiring them? Also...how can I just power the motor to make sure it is working? two wires to each seat. dead easy. Don't really even need to do that, connect them to a battery charger get them in to the right position and thats it. Not touched mine since i put them in. Quote Share this post Link to post Share on other sites
Krazee 0 Posted April 17, 2006 So I can just run them to the battery? how do I change between up and down? Quote Share this post Link to post Share on other sites
billinjah 0 Posted April 17, 2006 youll need the original switches but if you dont have them reversing polarity will get them in the right position. Quote Share this post Link to post Share on other sites
