willg 0 Posted April 14, 2006 couple of questions if anyone can help. when it rains the passenger door fills with water and i almost sure it comes through the horizontal door/window seal. a) does any no who could fix it b) has any one got the same problem and rectified it c) anyone know of any part number i am really that bad when it comes to finding part numbers thanks Will 95 VR6 Quote Share this post Link to post Share on other sites
colinstubbs 0 Posted April 14, 2006 The doors are designed so that any water passing the seal (quite normal) drains out through the holes in the bottom! VW wax treated the doors inside so they shouldn't rust. Holes could be blocked? Is the water leaking inside the car itself? If so the door's waterproof membrane probably needs resealing/replacing. Quote Share this post Link to post Share on other sites
VR6 0 Posted April 14, 2006 http://the-corrado.net/.archive/forum/viewtopic.php?t=38141 http://the-corrado.net/.archive/forum/viewtopic.php?t=31616 http://the-corrado.net/.archive/forum/viewtopic.php?t=19626 http://the-corrado.net/.archive/forum/viewtopic.php?t=5360 http://the-corrado.net/.archive/forum/viewtopic.php?t=19295 http://the-corrado.net/.archive/forum/viewtopic.php?t=11892 Quote Share this post Link to post Share on other sites
willg 0 Posted April 14, 2006 thanks for the help. Water is not soaking the carpet in anyway, i replaced the heater matrix just yesterday in fact. The problem is i think water is running down the windo and past the outer window seal and building up in the door. When i opened the door yesterday water started poooring out of the bottom - through the holes in the bottom of the door. colinstubbs reckons this is normal and the door can cope with it because of the wax waterproofing. problem being i think there may be too much water getting through the seal and there is signs of the paint starting to bubble. Do you think it is the case of just rewaxing the inner door then cheers Will Quote Share this post Link to post Share on other sites
Trig 0 Posted April 14, 2006 Yeah it'll be the weather strip bit that butts up against the window. It is a common problem for it to warp. Water should fall through though assuming the holes in the bottom aren't blocked. Don't think anyone has sorted out the weather strip problem yet, do a search. Quote Share this post Link to post Share on other sites
willg 0 Posted April 15, 2006 does anyone do replacements that you know of Quote Share this post Link to post Share on other sites
Trig 0 Posted April 15, 2006 The dealers?! :lol: Got a feeling they aren't cheap though and a bit of a hassle to fit... Quote Share this post Link to post Share on other sites
colinstubbs 0 Posted April 15, 2006 535 837 473 A (01C) ---LEFT 535 837 474 A (01C) ---RIGHT 8) Quote Share this post Link to post Share on other sites
willg 0 Posted April 15, 2006 cool cheers for that Quote Share this post Link to post Share on other sites
