tonertron
Front speaker question.
I was wondering........the front door speaker are not working in my corrado.....they werent when I bought it. The tweeters are fine, but the rears need changing as well.
To keep costs down, I was going to chuck the JBL 4x6 speakers in the rear, but I was wondering........rather than go the expense of getting a set of component speakers, would it be really crap to have a set of 2 ways in the door, and still have the tweeters in the dash???
I know I'm being a cheep fecker......but I wanted know from a technical perspective if this was ok to do, rather than from an audiophile one.
a '91 valver may not have door speakers at all, if your dash speakers are mid-range and not small tweeters then you still have the basic 16v setup, nothing in the doors.
There are speakers in the doors......they just dont work, and so need replacing.
It depends on what sort of sounds you want. For cheapness, use a personal hi-fi with headphones! 2-way in the door will be better, low cost components better.......
I used the entry level Magnat components in door & dash (£50) with 6x9's in the rear shelf (£50), much better than the JBL's!
my advice would be too spend more on a set of front comps and a pair of cheap ish 6x9's in the rear... since i changed to a set of focal comps in the front the sound difference even with cheap ish 6x9's is much better.... look on ebay get some 2nd hand ones and save yourself a small fortune!!!
