Steve_LD6U 0 Posted April 25, 2006 I am having to use 6mm spacers to clear the front calipers (am going to run 6mm front and rear to keep it looking right) Will i need to use longer bolts for this and ifso where can i get them . Cheers steve Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted April 25, 2006 Should be OK. I used 6mm spacers on my rear wheels and didn't need longer bolts. So long as there are at least 5 threads in the hub, you should be OK. Clean the bolts, put a small bit copper grease on the ends, torque one in, take it out and it'll show you how many threads are used. If not enough threads, I got some 35mm bolts (standard length is 28mm) from http://www.balancemotorsport.co.uk next day delivery. They're a flat bolt type with cones which you slide on to either make a taper or radius fit, so they can be used on any wheel. Quote Share this post Link to post Share on other sites
Furkz 0 Posted April 25, 2006 No u dont need longer bolts for 6mm Quote Share this post Link to post Share on other sites
