quicky1980
Adjusting passat sunroof
I have a glass sunroof from a passat estate in my rado but the front is slightly higher than the back, how do i adjust this? is there a screw to adjust or something?
I found a search result which and it states that I should put washers under the sunroof bolts but rather do the adjusting properly if possible
ta
the actual panel is held to the mech with four torx bolts that can be loosened to allow adjustment of the height of the panel - tilt the sunroof and you'll see two either side.
slide the cover panel back from inside and you should be able to see two torx screws on each side, just below the glass panel. loosen, adjust, tighten!
