localhost.80
1990 Corrado G60 USA Specs QUESTIONS....
Questions
Trunk Release latch where is it?
Power Locks on all models?
How do I clean the intercooler?
Recommend Type of Gas?
Side Fender Lights Relay or Fuse?
Number [53] Relay?
How come my windows can not be opened at the same time(Power Windows)
How do you use the MFA and Rear Wipers?
Unpluged Wire Connection under charcoal canister?
Head lights does not have a bright light?
Answers
Should be a lock/button to the right of the licence plate on the trunk.
Yup, vacuum operated though.
Ooh, don't know that one.
Anything above 95RON, though 98RON and higher is preferable.
Number [53] Relay?
Factory design, stops the circuits being overloaded.
MFA is the button on the end of the RHS stalk, and the slider on the stalk. Rear wipers - push the RHS stalk towards the dash to start, and again to stop.
Because the headlight circuit goes all the way up to the switch and back you get a voltage drop. Search on here for "headlight AND loom"
yip............with the key thats in the ign switch :D .................so take key out of ign then walk to back of car,insert key into boot lock turn and voila its opened :?: :lol:
about the gas/petrol USA has a differant rating system to us, put the highest grade in that you can get.
