Danger Mouse 0 Posted September 17, 2003 i cant seem to get my sony stereo to work properly. its plays fine but when i turn the engine off and leave it for several minuted all my setting are reset. Iv had this problem before on my golf and my mondeo ( sorry i know its a ford, its a mondeo, i know it sucks, get over it ). anyway no matter how many wires I switch around I cant seem to get the blasted thing to keep the settings I want. I was under the impression that VW and sony has some kind of partnership (if thats the best way to describe it) and that they use sony connectors for their stereo systems. Don't understand why I cant get mine to work. Any help would be greatly appreciated. DM Quote Share this post Link to post Share on other sites
Andi 2,147,483,647 Posted September 17, 2003 Sounds like the common permnament/ignition live problem. I would check your red and yellow power wires. If you have just used an ISO block, you will need to swap the Red and Yellow wires - and hopefully that should be it. If it's still not working, I'd get a voltmeter out and check your ignition live only works with the ignition, and that your permnament live is indeed permnament. Quote Share this post Link to post Share on other sites
Danger Mouse 0 Posted September 17, 2003 thanks andi iv been trying the red and yellow wires and unfortunately it doesnt seem to work ill get the ignition live checked thanks again DM Quote Share this post Link to post Share on other sites
Supercharged 2 Posted September 17, 2003 Yes it should be just a case of swapping the red and yellow ones, have you also tried the other combo of 2 wires into one??? Quote Share this post Link to post Share on other sites
G60Jet 1 Posted September 17, 2003 on some sony stereos there is a small switch on the case (under side i think) that allows the radio to be set up correctly. so you dont need to switch any wires. but i dont know if they still come on the new ones. Quote Share this post Link to post Share on other sites
chrishill 0 Posted September 22, 2003 I have a sony headunit and i ended up putting both the red and yellow wires in to one, means I dont have to have the ignition on to listen to the radio! :D Not sure how well this would work if your headunit wasnt a 'face off' type, it may drain the battery! at least with the face off you know its deffinatly off.... Quote Share this post Link to post Share on other sites
Henny 0 Posted September 22, 2003 I have a sony headunit and i ended up putting both the red and yellow wires in to one, means I dont have to have the ignition on to listen to the radio! :D Not sure how well this would work if your headunit wasnt a 'face off' type, it may drain the battery! at least with the face off you know its deffinatly off.... I wire all of my car stereos like this 'cos it annoys the hell outta me having to have the ignition on to listen to the stereo... :lol: Quote Share this post Link to post Share on other sites
Andi 2,147,483,647 Posted September 22, 2003 I've got a Kenwood Mask on mine - same sorta thing, I've actually wired it so that the stereo is on no matter what - and it makes me mask it (its a manual one) every time I leave the car to turn it off. Quote Share this post Link to post Share on other sites
Danger Mouse 0 Posted September 22, 2003 hey all if i put both wires into one it doesnt come on at all im at a complete loss, i know its not the end of the world but its a pain the the a**e having to input my settins over and over DM Quote Share this post Link to post Share on other sites
Andi 2,147,483,647 Posted September 22, 2003 In order for the stereo to work all the time, you'll need permnament power running into both the ignition live and perm. live inputs. Have you tested the wires yet? Quote Share this post Link to post Share on other sites
G60Jet 1 Posted September 22, 2003 is there a setting on in the stereos setup menu to allow you to change the memory settings. some stereos do have such settings Quote Share this post Link to post Share on other sites
Andi 2,147,483,647 Posted September 22, 2003 is there a setting on in the stereos setup menu to allow you to change the memory settings. some stereos do have such settings There isn't on any of the Sony's I've used. What sorta setting, anyway, Nige? Quote Share this post Link to post Share on other sites
Danger Mouse 0 Posted September 22, 2003 iv been workin a lot at the moment im taking it down on wednesday to have the wires checked just thought id try easier options first thanks for all your help chapps DM Quote Share this post Link to post Share on other sites
Andi 2,147,483,647 Posted September 22, 2003 Sounds like you're missing a permnament live feed. It's unlikely to have been cut... it may be hanging somewhere down the back of the dash. Just hope to god it was taped up when removed from the last stereo..... :shock: Quote Share this post Link to post Share on other sites
Danger Mouse 0 Posted September 22, 2003 uv got me worried now :shock: think i may have little look behind the dash tomorrow, possibly with some rubber gloves thanks Andi ill let you know how it goes by wednesday at least Regards DM Quote Share this post Link to post Share on other sites
G60Jet 1 Posted September 22, 2003 Andi Basically when you go into the setting menu some radios have a power setup fuction that set up everything from main power to the length of time the radio stay on after you remove the keys. (i.e so the car bettery dont go flat if left on) Quote Share this post Link to post Share on other sites
Andi 2,147,483,647 Posted September 22, 2003 What would that have to do with it losing the settings after the capacitors have discharged, though? Quote Share this post Link to post Share on other sites
G60Jet 1 Posted September 22, 2003 basically it sets the stereo to hold it memory or not, not that hard to understand is it. i've installed loads of stereos and i've seen a few with these features. Quote Share this post Link to post Share on other sites
Andi 2,147,483,647 Posted September 22, 2003 No it doesn't, it means it keeps the stereo on, running off the perm. live, for the set amount of time, once the ignition live is turned off.... Settings only remain on a stereo if the permnament live is indeed permnament.... Quote Share this post Link to post Share on other sites
Supercharged 2 Posted September 22, 2003 Sounds like you're missing a permnament live feed. It's unlikely to have been cut... it may be hanging somewhere down the back of the dash. Yes, unforunetly alot of Corrados have had there stereo's nicked (or badly installed ) at one time or another - have you got any signs of this like cut wires or ones that have been re-connected with tape round them?? - It does sound like you need to get the multimeter out! Quote Share this post Link to post Share on other sites
G60Jet 1 Posted September 22, 2003 explain how some radios can hold there radio channels and presets even when disconnected all together then. they still need the code putting back in but they can hold the presets. bit of an arse that mine doesn't. like i said SOME have these features, so basically by setting the power setup correctly you can get the radio to hold its presets. i've only seen it once or twice and it supprised me when i saw it. Quote Share this post Link to post Share on other sites
Andi 2,147,483,647 Posted September 22, 2003 Ok, but never come accross that myself. Have installed 4 Sony headunits - from old to bang-upto-date - none of which had this feature.... and since this is about Sony headunits... Think in total I've done around 15 installs - and never come accross a permnament setting-saved headunit. Yes, some remember for a few minutes because of capacitors inside, but not seen one that lasts longer. Quote Share this post Link to post Share on other sites
G60Jet 1 Posted September 22, 2003 depends how they save the presets at the end of the day, nothing to do with wiring but i do now a sony unit i fitted to my dads passat had a dip switch on the bottem as mention up thread for the same reason. its possible that this dip switch has been replaced but a logic function in the electronics. Quote Share this post Link to post Share on other sites
Danger Mouse 0 Posted September 30, 2003 Hey all Just to let you know JoeM gave me a hand with the stereo this afternoon and its working fine. Cheers again Joe Thanks to everyone who gave some input. DM Quote Share this post Link to post Share on other sites
Supercharged 2 Posted September 30, 2003 Well tell us what he did then! :) Quote Share this post Link to post Share on other sites
