Gazman 0 Posted May 26, 2006 I was thinking of mounting a switch on the dashboard to control the central locking. Anyone already done this? Any advice gratefully received. With all the stories pf car-jacking about I think it would be prudent to have the doors locked when driving around town. Currently, when I press the driver or passenger door pins down, only that door locks - should all the doors (and boot etc) lock? Quote Share this post Link to post Share on other sites
CazzaVR 0 Posted May 26, 2006 All should lock when you press the driver's one down. Make sure that the cable from the driver's door handle is plugged in. You need the door card off. Quote Share this post Link to post Share on other sites
Guest Posted May 26, 2006 mine operate indipendantly too. cables seem fine, and the central locking and full closure works, just not from inside Quote Share this post Link to post Share on other sites
gradeAfailure 0 Posted May 26, 2006 ^^^^^^ ditto Quote Share this post Link to post Share on other sites
kerrinmay 0 Posted May 26, 2006 Well mine used to all lock by pressing down the drivers one when I first got the car, and then it stopped working and I thought I'd imagined it ever working, and then some weeks ago it started working again, but now it's not :( Could it be this cable that is mentioned above? Quote Share this post Link to post Share on other sites
gc 0 Posted May 26, 2006 Check out this web site it might help with installing a switch in the console. http://www.gti-vr6.net/wiki/index.php?t ... to_console Quote Share this post Link to post Share on other sites
Supercharged 2 Posted May 26, 2006 gc, cheers - nice link! ..and Welcome to the forum! :wink: Quote Share this post Link to post Share on other sites
Bobby 0 Posted May 29, 2006 I installed an internal switch i used the wiring that came of my broken corrado door handle when i fitted the passat handles. Just cut of the wiring from the old handle so you can plug the new switch straight into the original connection .Connect the the three wires to a two way rocker switch with three connection points (maplins) so that the car can be unlocked and locked by pressing the switch. Quote Share this post Link to post Share on other sites
Gazman 0 Posted May 30, 2006 Cheers guys, just need to find some time to look at this now. Quote Share this post Link to post Share on other sites
