Shaggy
G60 Pinking ???
Just changed it!
It did make a slight difference but the pinking is still there!!!
For the time being, until darren can fit me in... i ve had to adjust the water / methanol injection so that it kicks in at 10 - 11 psi as this seems to cure most of the pinking down the bottom of the power range there is still a slight pinking towards top end tho, which isnt ideal... :roll:
why dont you try it say 5 deg incase you have a really agressive chip?
on mine if you drove to redline at say 90% it would be okay...it just did it at wot
Also tried the 90% throttle to redline and there is no pinking at all, only at full WOT
